I own a stone and marble cutting factory equipped with several three-phase 380V electric motors.
My motors are:
- One 75kW motor
- Two 22kW motors
- Two 15kW motors
- Two 7kW motors
- Several smaller motors ranging from 1.5kW to 3kW
The actual measured power consumption during normal operation is approximately 80 to 100kW, even when the 75kW motor is running.
I want to install a solar power system without batteries (except for a small battery for nighttime lighting).
My goals are:
1. To power all factory loads directly with solar energy using a phased start/variable frequency control system for the larger motors.
2. To use the 265kW diesel generator only as a backup during cloudy weather or at night.
3. Exporting surplus solar energy to a local grid powered by diesel generators (250 kW and 500 kW generators).
4. Prioritizing factory loads and automatically exporting only unused solar energy.
5. In the event of factory closure, I want to export all available solar energy to the local grid as needed.
6. I do not want to import energy from the grid.
A supplier has offered me the following:
- A 154 kW photovoltaic solar panel system (214 panels x 720 W)
- A 160 kW solar pump/variable frequency inverter
My question is:
What is the best system design to achieve:
“Prioritizing loads and exporting surplus energy”?
Can this be achieved using solar variable frequency inverters in addition to a grid-tied inverter and an energy management system controller?
Or is there a better solution for a small industrial grid?
Additional Requirements:
I want to integrate a 265 kVA diesel generator into the system so that it automatically starts when solar power drops due to cloud cover, low solar irradiance, or high power demand.
My main objective is to ensure all motors operate continuously without interruption.
When solar power output falls below the required load, the generator should automatically start to meet the load.
When sufficient solar power is available and stabilizes, the generator should automatically shut down.
Is it possible to achieve seamless automatic generator start/stop using Victron equipment while ensuring all motors operate continuously without any interruption?
The motors must continue to operate during the transition between solar and generator power.
Thank you.
