Which inverter do I choose for a RV, I really don’t need shore-power.
# Victron Multiplus Inverter/Charger : 24/3000/70-16 - PMP242300001
# Victron Multiplus-II Inverter/Charger : 24/3000/70-32 - PMP242305010
# Victron Phoenix Inverter 230V Smart : 24/3000 - PIN242300000
help on deciding appreciated.
Which inverter you chose depends on the exact facilities you need from the inverter. However, I don’t know of an exact comparison table, so one has primarily to work from the data sheets.
According to the information I see, the Phoenix smart inverter has NO AC input or transfer switch. If you don’t need that, then this would be your option.
The Difference between the Multiplus and the Multiplus2 is a lot more subtle: The multiplus has 2 transformers inside, while the Multiplus2 has only one (any one know the real reason for this?). This makes the latter smaller, lighter and cheaper(?).
I’ve used a lot of the Multiplus 2 24/3000’s and found them to be very reliable.
