Switching brands
I have a Mastervolt MassSine 24/800 Inverter on my boat. It is coupled with a Mastervolt24/60-3 Chargemaster. This works when hooked to land in a marina (almost never),the Inverter has failed, it runs the galley (oven ignition, exhaust fan, and the water heaters)…on the other side (catamaran) I have a VictronMultiplus 24/300-75-50-120 for all my 120 AC needs, (I have Lithium batteries 2 banks of 800ah each) plus enough solar to supply them. I want to change the 230 side (failed Mastervolt to a Victron) I’m not sure which Victron to install, just inverter?, inverter/charger?..sorry for the long rant, appreciate all suggestions
I would look at the multiplus2 range of inverter/chargers, you don’t have to worry about the charger side, but it may be a useful backup…
thanks Mike, I also thought it a good choice
