VRM release notes 26-02-2025
Another Wednesday means another release to VRM! Let me tell you what we added:
  • You can now click on an arrow next to an advanced page widget, to scroll to where it is on the page
  • To get you back to the selection of widgets, we added a ‘scroll to top’ button to the advanced page as well
  • We made a fix for the annoyance that you couldn’t add a user individually if it was already linked to an installation through a team.
As always, these changes are available to you the next time you open VRM.
Have a great day,
Barbara from the VRM team.
:smile:
I actually had a discussion about that this week with a customer.
I tested it in beta VRM and it worked, but he tried in normal VRM and had problems.
I didn’t had the time to ask you about that but now it’s solved.
Thank you!
Thank you for your efforts , this arrows are much appreciated as I always scroll thru many advanced data
Would it be possible to adjust the spacing on VrM iOS app ,’so we can see the bottom battery data ; temp and time to go without scrolling down , I feel the circled spaces can be adjusted upwards on the ESS flow. Thank you
Happy you like the new feature!
I’ll see if we can optimize the space between the dashboard cards on mobile. As we try to facilitate for them to work well on all mobile screens, they aren’t always the most optimal for every screen and every installation, but we’ll consider it!
Thank you Barbara for replying, I would definitely appreciate it . As you know I have been with you guys for a decade now and maybe another decade and another until rapture ; so rest assured. Before I had EV charger , and no ESS , There wasn’t any issue with the spacing , now with ESS and ev , the app spacing came up , almost wanted to get a 16 pro max cos mine is 15 pro max and I tested the app on another 16 and found same issue , so I know it’s a minor tweak for you over a cup of coffee . Thank you immensely
@Barbara
Sort of related here.
I have an installation where i was the admin and also the admin of the linked team.
I removed myself as the admin of the installation forgetting that a team is also linked. The team though is user level only.
The problem is i cannot remove the team As we do not have sufficient privileges. Which is odd as a user only level can remove themselves from a site.
Summary
You are right, the logical functionality would be that user-only teams and groups can remove themselves, consistent with how it works for individual users.
This change won’t be done today, so if you want you can forward me the site id and I can remove your team from the site in question.
Thank you.
d41243b4e68c.
I unlinked your team!
Good morning Barbara
Also a minor tweak for your VRM improvements ; if we can pin some installations to the top of your overview page , would be helpful as well . Thank k you
Morning . I appreciate the space modifications done to VRM tabs , charging tab will it get the same treatment since it’s looking a bit off and can the space reduction I mentioned earlier be looked into while at it please ; thank you for your efforts
This will come sooner than you think :wink:
Thank you always
