VRM Portal – Generator control position & battery wattage display improvement
Suggestion for VRM Portal Display Improvement
(English version)
I would like to submit two suggestions for improving the VRM Portal interface:
  1. Generator Control
    • Currently, the generator control buttons are placed on the far right of the screen, partly outside the frame.
    • Suggestion: Move them slightly to the left so they remain fully visible and aligned on the right side with the Loads tile.
  2. Battery Wattage Display
    • The wattage associated with the batteries is currently shown in a smaller font and offset.
    • Suggestion: Display it directly next to the percentage (%) and use the same font size as the other wattage values (e.g. AC Loads and PV Charger).
:backhand_index_pointing_right: Please see the attached annotated image illustrating these two adjustments.
Thank you to the team for considering these suggestions, which aim to make the interface clearer and more consistent.
