Improvements to VRM and New UI for DC only systems
We need better visualization in VRM and new UI for DC only systems such as cars (campers) and DC only (or AC->DC) powered telco equipment.
See these images from the same setup:
First - it shows Inverter Off and AC load when there are none. These boxes shouldn’t be visible at all. In System setup - position of AC load should be option of no AC loads present.
Second - Alternator (via Orion XS 1400) is shown in GUI (great) but no in VRM (not great). It should be there instead of AC input in this case.
Third - the graph below in VRM should display Alternator energy bars - equivalent of green bars in Generator energy in AC setup
Fourth - there should be red consumption bars in the same graph. DC system is enabled and battery measures current correctly and reports back to Cerbo via BMS-Can.
Fifth - when the VRM graph is switched to consumption, the consumed DC energy should be divided correctly between Solar and Alternator.
Sixth - battery box in case of managed Lithium batteries in GUI and VRM should be reporting time-to-go similar to how it used to be with Lead Acid batteries and BMV… this feature is really being missed
Thanks
Totally agree! We have been asking Victron for updates to VRM portal for YEARS now but all forum posts have gone unanswered. It’s ludicrous they sell a Smartshunt with VE direct connection to Cerbo, which has a DC energy meter and claim that it can be displayed in the VRM portal but then it doesn’t. in ANY of the DC meter modes. DC systems are horribiy unsupported.
Would love to see VRM dashboard tiles for more DC devices covered in the Smartshunt DC meter menu such as Alternator, Generator, DC/DC charger and Wind Turbine.
Rich
We should at least have the option to hide AC in/out and inverter status in a DC only system. This is one of the main reasons I’m still running the GUI version 1 with Guimods.
I have commented on this elsewhere, same issue, we have telecom sites that are DC only no need for AC. I too have asked for a DC only panel and get nothing. Very sad for such a good piece of great as the Victron devices. We try to use them in all of these telecom sites, but sure would like to be able to turn off the ac icons and have a clean screen. Causes a lot of questions which I have to reply with do not pay it any attention.
there are check boxes for doing all kinds of other stuff, I find it frustrating that a coder cannot add one to turn those icones off for a nice clean screen for those of us who are DC only users.
Victron coders PLEASE listen to us.
DC only install here - very frustrating you can’t hide all these un-necessary tiles just taking up space.
Probably such thing is low priority…
But you can do it yourself.
I’ve just tested it now in gui-v1, because I don’t like gui-v2.
But I suppose the process is quite the same. Gui-v2 also contains qml files and you may need to recompile some wasm…
  1. Define a boolean DBus variable (eg. showInverter) that can be true or false.
  2. Import that path in the corresponding qml file.
  3. Place a few “visible” property statements on relevant IDs (eg. “visible: showInverter”)
Et voila. Show or hide the inverter, ac-loads and their (animated) connections.
Alex,
There are so many who need this mod, can you package it up or give some more in depth description of how to do it. I am no coder, but I can copy and paste and do mods to the code once I see how it flows. (I think) We are all wishing that the devs would listen to us, we are small systems but there are a lot more of us than I think Victron has an idea.
Hi guys, you are being heard:
In the latest Venus OS Beta, the New UI (gui-v2) now hides “AC Loads” if there is no inverter/charger or dedicated AC load devices (EV charging station, energy meters, Shelly’s, …) in the system (→ Venus OS v3.70~74 available for public testing - #2 ). And there are more UI-related improvements for DC-only systems planned.
Cliffhanger alert! Please elaborate.
If its not too bold to ask can we please please have DC loads as detected/approximated by the Lynx Shunt (ve.can) treated the same as it is by the smartshunts, i.e counted as consumption in VRM graphs etc? It just doesn’t make sense that lynx shunt doesnt work/report the same way.
Thanks for your consideration :slight_smile:
Finally! Thanks
Not just Lynx… battery monitors built in smart lithium batteries are missing this feature… there is absolutely no reason to install SmartShunt if the managed lithium battery in DC only system measures very precisely current and voltage. VRM should display red consumption graphs in this kind of setup too.
I just installed 3.70, the ac loads is indeed not visible on my DC system but the inverter/charger is still there. Is there supposed to be a way to remove it too?
