VRM, Firmware Update doesn't update Bluetooth Firmware
When you update firmware via VRM on MPPT’s and other Ve.Smart devices, the BT firmware isn’t updated.
Seems the only way to update the BT firmware is via BT, locally with Victron Connect.
Is this by design for some reason, or just a limitation?
This is a limitation of some of our products. When VictronConnect shows 2 cards in the product info menu, it means that it contains an internal bluetooth dongle that cannot be updated via de VE.Direct port.
Regards,
Thiemo van Engelen
