VE Connect will download the needed firmware files. you should not need to download anything else.
Can you still connect to the MPPT via bluetooth with the VE Connect app?
If not, then you will need a VE-direct / USB cable to connect with.
Like i explained, im not able to connect with rhe app over Bluetooth.
This since the latest update.
When i disconnect the solarpanel and power, everything works again.
But after a while is disappears again, so no connection over Bluetooth.
All worked fine the last years, so i assume the firmware 1.74 is the cause off this unstable behavior.
Im stil able to monitor with the usb connected panel but i prefer a working Bluetooth.
As workarround im trying to downgrade to a earlier version like 1.64.
I dowloaded this with extensies. Dup and when opening the file i tell it to use the victron app , but i see nothing..so no questons or upload 1.64 into the app for manual downgrade.??
