I have an EasySolar in a parallel grid setup. I’ve added a CT on the jack entry and I was hoping to get on VRM two AC load measurements.
One for consumers (heat pump) below CT
One for L1 displayed as critical load (rest of house)
I know the CT kinda moves the grid measurement higher up the AC-in line but it seems to just replace the internal one and make the internal one obsolete!?
Or is there some config I ought to do to have the desired display?
I was hoping the internal meter would keep measuring something, namely AC-out 1+2.
If it replaces internal and makes internal one useless it’s a bit of a shame. It would be good to be able to redirect its use for critical load.
I configured what I think is the right way but in doubt I thought I’d ask
I’ve tried classic and new UI as some posts have mentioned different results, but with no luck.
Do you have anything more specific in mind?
Heat pump consumption is included in the AC load figure reported as a whole.
I agree about Current sensor
Regarding AC-out, I do not believe it’s a measurement but rather a calculation.
