I am using an Orion XS 1400 from 12V chassis battery to 24V battery system in my van build. Orion is connected via VE.Direct to Cerbo GX. All firmware up-to-date. VRM portal shows alternator charging current value (though this seems to drop out to 0W periodically). Battery is being charged as expected.
When I create custom widgit in VRM to monitor my charging sources, I am able to pick the Orion XS 1400 device and select a number of parameters therein to monitor. However, none produce any trends in the widget.
My MPPT is also connected via VE.Direct and its output power is selected in the widget. This value displays history as expected.
Should I expect to see data for Orion XS 1400 charging?
