Orion XS not showing up on VRM portal
Hi Community
TLDR:
I can see all my devices in the device list on the VRM portal, but it doesn’t show up next to the MPPT in the devices on the dashboard so the only way to monitor it is through the remote console.
I have a marine installation comprising:
  • 1x Epoch 460aH lithium battery with canbus to Ekrano
  • Lynx shunt with canbus to Ekrano
  • 2x Lynx Distributors
  • 1x 100/50 MPPT and 600W solar
  • 1x Orion XS off alternator (via Argodiode)
  • 1x Smartshunt on my starter battery (via Argodiode)
I’m using DVCC controlled by the battery BMS (MPPT, Multiplus2 charger, and Orion are externally controlled).
I have several Ruuvi temperature/humidity sensors as well as resistive tank level inputs for my diesel and water tanks feeding back to the Ekrano.
My Ekrano is running VenusOS v3.60~11.
Question:
How do I get the Orion to show as a power source on the dashboard?
I have the same issue with Ekrano using version 3.53, did you manage to solve this?
Same issue here. Would be nice to see it there with the other chargers as well (the Phoenix Smart IP43 shows up)
For anyone else who finds this topic:
The Orion XS DC-DC charger now displays in the VRM.
