VRM API: Preferring Access Tokens to User/Pass for security
I’m exploring the VRM API in Postman using the documentation provided by Victron.
Of course there’s the authorization endpoint auth/login.
Requires user/pass and returns a “token” and “idUser”. The token should be used in all subsequent calls together with other parameters like “idUser” or “idSite” (for which you first need to call another endpoint that requires “idUser”).
However, it’s also possible to use endpoint installations/{{idSite}}/system-overview (and others) with an API access token that you can generate in the VRM portal in Preferences → Integrations → Access tokens.
Using the API access token it seems you don’t need to first auth/login to be able to use the other endpoints.
However, many endpoints need the {{idSite}} part to be specified, but that one you can only get using auth/login.
Using the API access token is preferential over user/pass for security reasons, I think. One, for they can easily be revoked by an admin-user and you could assign/revoke different access tokens to different parties.
There is an endpoint users/{{idUser}}/get-site-id but that requires you to know the “installation_identifier” for which you need the endpoint users/{{idUser}}/installations for which you (indeed) need the “idUser” again.
So, if I want to use API-access tokens how do I get the “idUser” without using “user/pass” authorization?
Or, how do I get the “siteId” without the need for a “idUser” in the first place?
Hey,
You should be able to get it by using: VRM API documentation
That will return your idUser and then you can use the installations endpoint you mentioned before to get the site-id.
I’m sure there is an easier way but I only needed to do it once since I have it now.
Cheers,
Kent
For security reasons I would like to be able to get an ‘idUser’ so that I, together with a provided “API Accesss Token” from the portal can do whatever with the API.
However, it seems you always first need to user auth/login which needs user/pass.
There seems no way around that.
https://vrmapi.victronenergy.com/v2/users/me provides the UserID, relate to then token.
Succes!
