What Victron device would you use to regulate voltage. Current Victron chargers are set at 14.6 V for lithium battery charge, appliances need to be limited to 12V. Going to install it between my bus and 12v panel. 40 amps @ 12V should be my max load.
Victron Orion XS 12/12 50A DC to DC charger which can be set in power supply mode to give a fixed output voltage. Max capacity 50A.
https://www.victronenergy.com/dc-dc-converters/orion-xs-dc-dc-battery-chargers
Can the input voltage change and it’s not an issue to the output? When my Ip22 is in charge mode it is outputting 14.6, when charged the battery should be around 13.5.
The Orion will deal with that range of input voltages.
Looked at the manual shouldn’t be an issue, thank you.
