I am finalising a new system on a twin engined boat and trying to get my head around the Orion XS 1400 DC-DC aspects. A lot of detail below but I thought it might help.
Gist of my question is how to ensure the 50A Orion XS 1400 DC-DC charger doesn’t deplete the boat start bank (input side) when there is less than 50A coming into the start bank (which will be the case more often than not), and whether I should be worried about constant cycling if it starts and stops based on voltage.
Components
17.5kVA generator (existing)
2x engine start banks. AGM @ 24v (existing).
2x engine 60A alternators (existing) – may change to larger alternator for house bank, but that is not straightforward for various reasons. Each feeds one 24v start bank.
1000ah @24v lithium house bank - new
Victron Quattro 24/8000-200 - new, for house bank.
Victron Centaur Charger 24/60-3 - new, for each start bank and generator start battery.
2x Victron XS1400 50A @ 24v - new
Cerbo GX MK2 - new
Principal charging for the time being will be periodic generator running, supplemented by alternators via DC-DC when underway. It would be a rare situation when generator and engines running simultaneously, but it could happen, e.g. when running water maker or very heavy loads.
My question relates to settings for the Orion XS DC-DC chargers which are rated to 50A but will often have less than 50A going into the start bank (which is their ‘input’ side).
I want them to work when main engines on and/or when generator is on.
60/3 Charger (i.e. when generator is running) will only put max 30A into each start bank.
Alts will be de-rated a bit and put in around 40A at higher RPM and less at slow cruise into each start bank. Output current on Orions will at least be limited to de-rated alt current.
I’ve heard conflicting messages about whether the Orion XS can sense input current and adjust output current accordingly, or whether you still set input charge start and end voltages, delays, etc. I think it is the latter, in which case (assuming I don’t set the max current of the DC-DC chargers to 30A) should I be worried about the fact I will necessarily be cycling the batteries when charging on the generator, and often doing so when at idle RPM via the alternator?
If so, one option would be to use the 60/3 charger relay as an input to the Cerbo GX to trigger a rule to set max charge on the Orions to 30A when that is the charge source for the start banks, and live with the alternator issue (which presumably is an issue for all DC-DC chargers connected to a start bank)?
Any comments gratefully accepted.
Thanks in advance.
