VM-3P75CT role as AC-Load - position settings
Question regarding VM-3P75CT Energymeter:
In Victron Connect you can select the role of the energy meter, wether it is a grid meter, pv inverter, ac load or generator.
When you select pc inverter, you can also select the position and depending on that setting it is shown at different positions on your dashboard.
I have it mounted on AC-Out right before my heating system. It is not measuring the complete AC-Load, just the energy for the heating system, but when I select AC-load, I cannot select any position. It is also not shown on the dashboard and AC-Load from the Multis is still showing the complete power consumption for my house + heating system. I would like to substract the power from the heating system from the complete load, so I have seperate values for the house and for the heating system. Is this something I could fix with Node:Red?
FW of the VM-3P75CT is 1.08.
Am I missing something or what´s the trick with this energymeter?
I have the same situation. Found you a solution ?
Thanks
Thomas
If you select role as EVCS or generator, you can see separate box with consumption, BUT this is not what we would like to have. I gave up with this feature already, I think it is just a “wet dream”. I have asked few times a questions regarding this issue, but no answer from Victron side. I know this is not a official Victron support channel, so I quess we just have to wait…and wait…
It would be really nice from Victron to give this really good energymeter a small firmware upgrade so you can install it at any position to monitor single loads.
