VM-3P75CT: is it possible to use ve.can and network/modbus/udp concurrently?
Is it possible to use/connect both the ve.can and network Ports concurrently?
Extra question: is there a limit on the number of ip addresses querying the device via the network port using modbus/udp?
I do that with a Cerbo on ve.can and a raspberry via network. Works fine.
I haven’t heard of any limit to the amount of queries for this model, it’s very fast so if there is one I don’t think you will reach it.
