Hello, I am working with 12 energy meters that have both VE.Can and Ethernet connections. I am planning to connect all 12 meters to an Ethernet switch, which will then be connected to the Cerbo GX. if anybody know if this setup will work? Note: It is not possible to connect through VE.Can because the MPPT charge controller is already connected to the Cerbo GX.
Thanks advance.
VE.Can is a bus system, all devices daisy chained and the first and last device in the VE.Can Bus gets one termination resistor.
You may need to keep an eye on cerbo load, depending what you intend to do.
It does not have limitless resources.
