VM-3P75CT - Feature Request
I have a single-phase power setup but want to use my VM-3P75CT meter to monitor 3 different sources:
Network Setup:
  • Ethernet runs to meter box (far from ESS)
  • Want to avoid adding network switch and extra monitors
  • All power data logged via Modbus for energy auditing
My Configuration:
  • Grid (on P1)
  • Solar (on P2)
  • Other loads (on P3)
Current Issues:
  • 3-phase setting: Can read all values via Modbus (great), but total power reported to ESS is wrong (as expected)
  • Single-phase setting: Total power is correct, but P2 and P3 registers all read as -1
Requested Changes:
  1. Minimum: Allow P2/P3 Modbus readings in single-phase mode
  2. Ideal: Enable “Grid + Solar + Load” or similar monitoring setup
Thanks!
Just came looking if the VM-3P75CT would do this after finding that ET112 meters are really hard to find these days.
It’s a shame this hasn’t been implemented yet 18 months later.
