Victron VM-3P75CT Energy Meter Alternative CTs Larger Frame
Has anyone sourced or used alternative CTs of same specification to those supplied with VM-3P75CT energy meter successfully?
The 10mm diameter is fine for smaller cables e.g. 16mm2, but for larger 25mm2 or 35mm2 a 16mm or 24mm frame size CT would be great. I would suspect they exist but there isn’t much to go by with lack of specifications.
I gather shelly manufacture the meter for Victron. I am wondering if the speciations are similar to those available from shelly.
Surely Victron could release some speciations of the CTs supplied?
Accuracy: 1%
Ratio: 3000:1 ?
Rated primary current: 80A?
Secondary Current: 16.67mA ?
Saturation current ?
Load resistance?
Burden Resistor?
I would surprised if it’s a bespoke CT. Surely must be standard off the shelf CTs that will work.
The new Victron energy meter model that will support standard 5A CTs, but also different current ratings is highly welcome. I hope it will be available soon.
This is the used CT:
https://nl.mouser.com/nl/ProductDetail/KEMET/C-CT-0810?qs=doiCPypUmgFbdNX%252Bmy9Z2Q%3D%3D
It’s mentioned in the manual:
There will be a new VM-3P5A soon that supports all standard CT with 5A.
@M_Lange thanks for sharing this information. I didn’t spot that link!
From the Kemet datasheet the specs are provided.
It does seem challenging to find a similar alternative with bigger diameter. However I see in the same Kemet model range a 120A CT is available with 16mm diameter.
This outputs a higher 400mV @ 120A primary current, however based on the charts in the datasheet it would appear at 80A primary current load it should output similar voltage as the Victron supplied CT, following similar linear curve, so should be fairly accurate?
Worth getting a sample and testing I think.
I wonder within the energy meter, can the ADC circuitry support input beyond 270mV and thus is there capability to meter beyond 80A, or would damage occur? I notice with the 80A CT upto 120A is possible and with the 120A CT upto 150A is possible, subject to design of the energy meter.
Has anyone exceeded 80A measurement with the VM-3P75CT?
@guystewart. It would be nice if Victron can advise if the C/CT-1216 can be supported or not with the VM-3P75CT
Upon looking where to procure a sample I do notice one of your UK ‘Authorised Distributors’ is selling it.
For your application there is a new version: the VM-3P5A. Basically the same meter with a generic CT input. Any CT that has a nominal secondary current of 5A is applicable (and that is a big pool!). In the setting you can set the primary current.
The news has been out since about 2 months. I’m not sure if it’s available yet.
There was a news about the 3P5A? Can’t find it.
No it still can’t be ordered.
I did know about it… but I can’t find anything in my old mails.
It is mentioned in the blogpost about Intersolar on June 17th. And in May in a thread here.
Ah, ok so it’s this blog post.
I believe Victron originally suggested a release in Q1 of 2026. That’s clearly been and gone, so has Q2 so I’d imagine it’ll be pretty soon.
regarding the kemet clamp, I’ve been using it for a while and it performs identically to the supplied clamp as far as I can tell. I do not exceed 80amps so can’t advise how the meter responds in that scenario.
My last information is July, so basically now, but it’s not in the Q3 price list and not in e-order for distributors.
I guess there is another delay for a few weeks.
Yes the 5A CT Meter will be much better solution once it becomes available. For now it’s possible to work with the current VM3P75CT.
Larger 120A CT has arrived. Some photos for size comparison;
Unusual that the direction K>L appears reversed based on the split format.
Have carried out some preliminary testing. Installed the new CT on separate meter, and clipped onto same cable (Load) to compare accuracy of readings with a Victron supplied CT.
Testing carried out at different load levels.
Results are promising;
Verified current readings with clamp meter.
Can certainly conclude the CT works fine up to the Victron meter rating of 80A.
Did some short testing beyond 80A load, upto around 95A. After 80A, the readings on the meter become inaccurate and max out in high 80s.
Can therefore conclude there is hardware/software limitations within the current meter, and it is indeed just designed to meter upto the 80A specification.
Either way this CT solution is ideal for standard supplies, and solves the problem if you have larger cables / meter tails.
In the UK the CT is available from both RS components and Farnell.
@Victron feedback on whether this is approved for use would be appreciated.
Continuing the discussion from Victron VM-3P75CT Energy Meter Alternative CTs Larger Frame:
The tech specs and the manual state that for that model it is rated for 75A 80A max. Thata pretty official statement as the the device limits. What more is needed?
And the specs all
clearly laid out in the manual.
If the reading is close to accurate seems to be working ok then it should be ok to use if the gauge wire is the issue. But the reading limits are definitely mentioned at 80A.
@lxonline As you have summarised indeed it’s conculsive that the VM-3P75CT is suitable only for upto 80A max as per Victron datasheet.
A few weeks on I can confirm the larger CTs are working 100% well and suitable solution if cable size is the challenge which was my problem.
It would better if Victron sold the VM-3P75CT without CTs, at a lower cost, as it’s a waste having lots of spares, particularly if only using the kit for single phase. In the above setup I used 3 of the larger frame CTs and thus the 9 CTs supplied are unused.
It was a worthwhile test bench testing beyond the 80A limit to see what was the limiting factor actually was, as no one had the answer on whether it was the meter hardware or the CTs. Now we know. As Victron supply the kit with CTs suitable for 80A, of course the datasheet would have to state 80A max.
More is needed hence why the VM-3P5A is being launched for higher current requirements.
In the interim until it becomes available will just have to use compatible Carlo Gavazzi or ABB meters that support higher current.
When the VM-3P5A is released, I would like to think it will be sold by Victron without 5A CTs so you can choose appropriate ones and quantity needed to requirements.
This has finally been released
For my domestic application, where measuring below 10A amps is needed, 5A secondary isn’t much use. I’ll be sticking with the work around of using Kemet ct-1216 clamps. According to their datasheet (https://yageogroup.com/component-documentation/download/specsheet/C/CT-1216?lang=en) the clamps have the same 3000:1 turn ratio as the standard clamps and operate at a max output of 400mV so are in fact an ideal replacement for the original clamps.
I read it as: several ct types from up to 10A maximum current.. and up to 6000A maximum current.
the issue I see is the 5A secondary current requirement. I want to prevent export to the grid, so want to have a grid set point of 50w. Even class S clamps, which have an accuracy of down to 1% of their normal current (as I understand it), means on 240v a 100/5A class S clamp will only be accurate down to 1A or 240w
As I don’t need 100A (I have no EV charger for instance), I just need a 16mm diameter clamp, so I’m happy to live with the restriction of 80A on the VM-3P75CT and have a much greater accuracy of lower currents using relatively cheaper CT clamps.
Hopefully someone else will come along and provide more information as I’m NOT a qualified electrical engineer.
Maybe @PeakShaving can get one a do another investigation for a UK domestic setting? :grinning_face:
Hi @drs68, this is not how the accuracy class for CTs is defined.
Accuracy class is based on the maximum error percentage of a reading over a specified range. For instance, Class 1 CTs will have a maximum error of 1% from 10% load to 100% load. So a 100A CT will have a maximum error of 1A at full load, but at 10% load the maximum error is only 0.1A. See this document by ABB for more info on other classes or light-load accuracy.
By choosing the right CT for your application, the VM-3P5A can achieve the same accuracy as the VM-3P75CT or even better.
Hi Luc,
I guess the question then is which class of CT to use for an installation on a 240v 100A domestic supply that can sufficiently accurately measure to hold a grid set point of 50w which is only 0.2A and therefore 0.2% of the CT’s maximum? The link you provided was very informative, but only provides accuracy down to 5% of rated current, which is approximately 0.1, i.e. 0.5A, which is 120w. There is no information regarding accuracy below that.
Does you have any data for the VM-3P5A’s accuracy/resolution when used with a 100/5 A CT at around 0.2–1% of rated current? In other words, given my target of 50w set point, is the VM-3P5A a suitable alternative to the VM-3P75CT at all, I.e. would it perform at least as well as the VM-3P75CT does if the VM-3P5A is paired with a 100/5A CT (which would also need to be a split clamp)?
thanks.
i saw installations where the wind the cable 2 or 3 times through the CT - maybe a solution to get better accuracy?
But yes, space problem…
Unless the meter is designed to be calibrated to ‘know’ this is happening the result would just be that the current reading is multiplied by the number of times the cable is wound through.
Then there is the addition of the extra winding amplifying the noise as well, which will also also part in messing with reading accuracy.
