Victron VM-3P75CT alternative CT for UK meter tails
I just got a few VM-3P75CT boxes to measure consumption current from the grid here. One was planned to go on my house - 2 for our boat.
But all our standard UK meter tails here are now per regulation 25mm2 with 10.5 to 12mm diameter dependent on brand/insulation. (80 or 100A fused) - but the included CT only allow for 10mm diameter cable - and very strict 10mm…
If you replace the CT if it breaks- it is no longer calibrated the manual says. But there is no mention of a calibration function? (I have no issue precision calibrating AC Amp both 1 and 3 phase - got the tools)
So could I replace the Kemet C/CT-0810 with the C/CT-1216 and calibrate it? I know I will loose resolution… Or do I have to try and find 9.8mm meter tails @ 25mm2?
I have in all my “AC measurement devices” never received one before with 10mm current clamp designed for grid measurement. From Smappee to Enphase and many others - they all allow for 16+mm diameter meter tails.
/k
The meter is rated for 75A (max 80) so closest suitable is 16mm2 and onto which the clamps will easily fit. Unfortunately using other CTs and self calibrating is not possibly. The EM540 is another option.
I have a duplex Hager CU with the flexi links they are 25mm @100amp it can just about fit the clamp due to the cable insulation being flexible. But double insulated tails no chance, which is the UK standard, a lot of energy provides swap the 16mm for 25mm with isolation point when smart meter installations are done at least on a single phase install, so a lot of people could be fine but then find out that it no longer fits after a smart meter install. I do think that a clamp upgrade should be looked at @guystewart can you look at alternatives for CT or have one for the UK market? As @ejrossouw has said that’s a good alternative but more invasive but that would take 25mm tails no issues
Hi @Daza,
We are working on an improvement to allow more flexibility to the CTs. I am not sure the progress, but it is a priority feature for the energy meter team.
It will be announced on Victron Professional News once it is shipped
Hi @guystewart - that sounds great. If they want a beta tester - please let me know. I have high precision Fluke energy meters I can check with.
Great to hear @guystewart would like to see the device opened to maybe have the different CT’s monitoring different sources ie CT1 grid CT2 Solar CT3 heat pump as examples that would be awesome
We have previously implemented something similar for other energy meter brands, so I expect it’s in the plan even though I haven’t heard anything internally.
Well I’m all for using the extra phase inputs for other single phase devices as well!
please… :slight_smile: @guystewart
@guystewart Hi Guy. Any update on this. We have a few applications where we would like to use the victron meter rather than the alternatives (IP connectivity helps a lot rather than USB / Zigbee)
Be great to have an option to use this in the UK
Hi Guy, Is there any update on when we might see the ability to configure for different ct’s. I have a requirement for 100A mains connection. I also have high speed and high accuracy logging on a second metering device for the generator export control for comparison if you need beta testers.
@guystewart hello Gay, is there any update on this matter??
Additionally, is there any plan to allow for an open energy meter configuration? For instance, if we are using a CT with a ratio of 3000 or 4000, we can connect any CT and configure the ratio based on its capacity.
Please look forward to our upcoming event at Munich Intersolar in May where any new product announcement would be made :slight_smile:
Hopefully a device that can also integrate the Lynx distributor to the cerbo GX directly would be nice :wink:
Guy. I see the new meter announcement. When will there be any more details on specifics
We are installing a 9 Quattro 48/15000 system next and the incoming 3 phase mains is twin 120mm cables per phase ! . We are really struggling with a CT for such huge cables.
Perfect solution would be support for rogowski ct
Where is the new meter announcements? :slight_smile:
Scrub that it was the 2024 announcement. I got excited too quickly. @guystewart you said there should be something announced at inersolar about energy meters and ct. is there a link to what was announced or any other update
I’ll find out what more information I can provide.
There are no news on the website - it would be great with an update from what was announced. But last press release on the website is pre-Covid….
Unfortunately there is nothing further to share yet :frowning:
This new energy meter product that will allow other size CTs is still under active development. I’d hoped it would be ready by now also, but that is the nature of hardware development.
