Victron multiplus2 8 kw and 2 10 kwh dyness battery. Cerbo finds battery and battery dip.switches are correct. The issue I’m having is when a pump (1 kw ) or a floor grinder or skill saw starts up the inverter instantly goes into low battery and shut down. Cerbo will either turn off or stays on when the load starts. System works with a heat gun load no problems. When I try the same loads on my home system 4 kwh BYD and a 3 kw multiplus2 it operates them (a bit of a struggle to start with ) setting inside inverters are exactly the same and systems are dedicated off grid. Does anyone have any ideas what the issue could be.
Related topics
| Topic | Replies | Views | Activity | |
| Low Battery Voltage Error on MultiPlus-II 10000/140 with Dyness DL5.0C Batteries (with Heating) | 17 | 733 | 8 October 2025 | |
| Low battery voltage after overload | 5 | 83 | 15 August 2026 | |
| RV installation with MultiPlus II - new installation | 25 | 6611 | 1 March 2026 | |
| Brand new Multiplus II 6k5 Dc short in 3 hours lifetime, with no load | 17 | 690 | 5 May 2026 | |
| Multiplus-II 48/5000 inverter stops at ~ 3x3450 W and does not go above | 13 | 431 | 20 April 2026 |
