Hi. One week ago I was installing a brand new Multiplus 48 II 6K5, but not connected yet to the house electric system, because I want it to work in AC Coupling with a Gen 24 fronius, and to do that, first of all I need to upgrade the electrical pannel. So once installed, the batteries are connected and the inverter works fine, 230Vac out, and 0,6Amps DC with nothing connected on AC out1 or AC out 2. Yesterday we continue, to include the CERBO and set up the system, but the two (brand new too) Dyness DL5.0C PRO were at 27% and decided to connect the AC IN in order to charge, and works fine as i expected. First with a charge current limitation of 10Amps, and then to 20Amps because I wanted to stay on the gen24 production at the moment. Well, I did try to disconnect AC In and connect again, to restart charging (it works OK), and do the same but with the (1-0-II) Switch, and it did work well too. So yesterday ends with the batteries at 37% and all the night the inverter had 48V pressence, but stopped on the (0) switch possition, and without AC IN. No power consumption from the inverter, but the CERBO.
Today when the GEN24 was producing enough energy, with no AC IN yet, 37% batteries and I pressed the switch to (I) , the show beggins. CERBO goes OFF inmediately, strong noise and alarm from the batteries. The BMS was protecting and retry every x seconds. Open fuses from booth batteries, and the next retry they work fine. I did open the CERBO fuse (I wan not draw current), close the Precharge circuit, and measure at the VICTRON DC input, and the voltage was not increasing as the capacitors bank charges, because it is a shortcircuit.
I was in shock, because this inverter had no the oportunity to work, today I was planning to test it with a real load when I had the batteries fully charged, but..
This is the schematic. I always put individual protection on the battery side, so you can see two fuses instead of one.
When I first connected AC In to charge Batteries and passing from 10A to 20 Amps charge.
The VICTRON electrical pannel it’s not connected yet. there is a By-Pass and the inverter output protection.
The batteries.
I’m still with the pocker face.. Anybody has experienced some like this? The inverter is on the box, waiting to do a dealer call next week.
Thanks
Hi all.
Today is arrived the inverter, with that repairing note.
Maybe this weekend will hang it again and works well.
Thanks for all the help.
