Victron lfp internal balance start voltage per cell?
Hi everyone, I have some older victron non-smart lfp cells with the 3 pin bms communication leads and internal cell balancing. I’m repurposing them to a new system, and as they are showing their age regarding voltage of series connected packs, I would ideally like to set the absorbtion voltage a little lower than the victron recommended 14.2V per pack. Does anyone have any details on the balance start voltage (and perhaps voltage differential trigger) used in victron lfp internal cell balancing logic? I would like to set the absobtion voltage equal to or very slightly above the sum of this start voltage, in order to avoid going right up to the steeper parts of the charge curve and keep the pack imbalance a bit more minimal. Currently i’m seeing pack to pack imbalances of around 150mv when using recommended absorbtion voltage of 14.2v.
Thanks for reading, all input welcomed!
Hi Chris,
Have a look at the 8.3. Cell balancing part of the LBS manual.
Thanks for the reply,
I will try them for a while at 14v per pack, hopefully this will top balance the cells at 3.5v given enough time.
