Hello all,
We had an old system running fine for years with three Victron inverters (Phoenix Inverter 24/5000 230VAC PN# PIN245020000) running in parallel (firmware 1949159). Which means:
19 - VE.Bus - old microprocessor, 230VAC
49 - Model: Multiplus 24/5000/120-50 (Why is an Inverter identified as model “Multiplus”??)
159 - firmware version
Then one unit failed, and we purchased a new inverter with the same part number (PIN245020000). When we received the new unit, we connected it to the computer, and the device showed the following firmware: 2614497, which means:
26 - VE.bus - new microprocessor, 230VAC
14 - Model: Multiplus 24/5000/120-100 (again, an inverter identified as Multiplus)
497 - firmware version
On document: “VE.Bus firmware versions explained v24”, we have the following:
“Units with old and new microprocessors can be used together in parallel and three-phase installations without any problems. Combining virtual switch firmware (100 – 199) with assistant firmware (200 – 499) is not possible. It is important to always use the same, and the last, firmware in each unit.”
We can no longer configure the three units in parallel. We tried the following:
- Update the old unit to the latest version: 1949206
- Update the new unit to the latest version: 2614556
didn’t work
- Downgrade the new unit to the same firmware version as the old ones: 2614206
didn’t work
The VE Configure software always shows:
- “Devices must have the same firmware version.”
- “Only devices of same type are allowed”
From the file “VEBus firmware number.txt” we can get:
List of models:
- 1949 MultiPlus 24/5000/120-50
- 2614 MultiPlus 24/5000/120-100
- 2649 MultiPlus 24/5000/120-50
Questions:
- Why did Inverters come with a “Multiplus” model firmware?
- Why same Part Number products come with firmware indicating a different model (14 vs. 49)
- Can I install firmware 2649206 on the new unit?
