2 x Multiplus ii 8Kva Not working in parallel
Good day
Just finished wiring 2 x Multiplus ii 8kVa inverters in parallel
External Transfer switch and External Ground relay both wired according to the manual
inverters connected perfectly in parallel
inverters have different firmware, but same Comp ID, and Victron supplier confirmed they are compatible
S99 inverter firmware used
100A Victron CT installed
Grid code used: “Other, not compliant to any grid standard”
NO Ziehl relay used
When I switch the system ON, it’s not engaging. The Master inverter has all 3 charge status LEDs flashing
Manual says it’s a configuration or CT issue, but I can’t figure out where exactly I missed it
Is there anyone who can assist me remotely on site, as this is pretty urgent
What do you mean by this?
All systems should be on the same version.
Those 3 flashing LEDs mean Hardware or EEPROM error - in this case a config mismatch of sorts.
The community can’t offer that kind of support, it is not a support site. You will need to involve your supplier for assistance.
Please see attached compatibility ID form from Victron
I’m connecting 2 inverters, 3 years apart, in parallel
Old inverter Serial number: HQ2220C4VY3
Old inverter firmware: 2621563-s99
New inverter Serial number: HQ2545YNP6P
New inverter firmware: 2682563-s99
New inverter Comp ID 2621_A
Old inverter does not have a Comp ID on the sticker, meaning the first 4 digits of the firmware plus A is the Comp ID (Which is 2621_A)
According to Victron, these inverters can be paralleled (see attached reply from my dealer), so I guess that removes the inverter compatibility issue
The inverters are also syncing in parallel with no issue.
If you can please let me know if there are other settings that I skipped, or if this was not a very accurate answer
Another test done
I’ve tested the old inverter, which is the Master, as a standalone, and it engaged perfectly. I couldn’t test the new one because I didn’t have a compatible CT for it. I’ll test it on thursday and give feedback
See also attached VE Config screenshots
2026-05 - Compatibility ID explanation and handling guidelines.pdf (505.4 KB)
Have you enabled the external CT on the master, configured the rating? The secondary unit doesn’t need one, there is one per phase.
Comp ID’s are right, so something else is off.
Maybe attach your remote config file here from VRM.
If all else fails, flash them with veflash and try again.
I was thinking about this. The one confog error inhave seen twice is this one
Grouping them incorrectly.
Group 1 is masters for all phases
Group 2 for slaves.
Thank you
I programmed the parallel setup using VE Quick configure. Didn’t think it would make a difference since it’s only 2 inverters parallel in single phase.
I will use the VE System configurator when I get back to site
All Victron multi inverter systems are configured with VE.Bus System Configurator. And through it all inverters are programmed through it (right click and configure) ve bus config like singe unit ve bus systems are.
Thank you
I reprogrammed the inverters with System VE Configurator, like what you said. Everything is working perfectly now. The 2 inverters, though having different Firmware versions, have the same Component IDs, which makes them compatible
Ultimately they should both be updated to the same firmware.
Excellent. Glad you are up and running
