Hi there,
Does any know how 2 x EV chargers will connect to the 1 x Cerbo GX system, will it get confused or can it handle 2 chargers and can you set a priority
I dont think there is a problem to connect 2-3-4 charges, as charger is integrated via modbus, so all you have is more devices. I think if you connect them on inverter ac-out they will share solar and split it between them (but this is my guess)
thanks for the info
yes, that’s correct, I saw a system with mote than 10 units
