Victron connect Bluetooth issue after upgrade
I have been able to update my configsys settings over Bluetooth - right up until this morning, when Victron updated me to version 6.32. Now it says I cannot upload configsys settings without a direct physical connection.
a) Is there a way around this limitation?
b) Is it possible to go back to the previous software version which DOES allow me to update configsys settings?
Thanks!
Bill
You will need to be a bit more clear about what devices etc.
Victron doesn’t update any of your devices.
Do you mean Victron connect app?
VRM is something else.
I beg your pardon - yes, I mean Victron Connect. It updated this morning and now I can’t upload Configsys files.
Can you try reproducing it, create a system report and post it here.
I have amended the topic title.
I think the program is working - it’s just that this new version of the program prevents me from uploading configsys files to the multiplus via the VRM/web. The old version allowed it. I’d like to revert to the old version if there is not a workaround for this as I really don’t want to buy a new dongle or whatever and have to connect it every time I change a parameter. Being able to switch between different configsys profiles is critical to my application (RV running remotely and occassionally being plugged into shore power with limited current available).
Modifying VE.Bus Inverter/Charger settings via remote connection (VRM) is not supported by VictronConnect. Remote configuration works for VE.Direct and VE.Can products.
For remote configure a MultiPlus or Quattro you need to do it via the VRM portal website in combination with VEConfigure to modify the settings.
