Victron Cerbo GX and Fronius Verto
I am in the planing stages of a 45kWp solar system with battery storage. For PV inverting I would like to use a Fronius Verto Inverter, but looking at the Victron Documentation (AC-coupled PV with Fronius PV Inverters [Victron Energy]), Fronius Vertos are not mentioned. Am I correct to assume that hence Vertos are absolutely incompatible and won´t work with the built in support in the GX?
The Fronius Verto has only just been released and first deliveries to distributors are just coming in, so it is unlikely anyone has real world experience yet. That said the Verto uses the same communication board as the Fronius Gen24 inverters so I’d expect it to work with the same caveats covered in sections 2.1 and 2.2.1.4 of the AC coupling document you linked.
The integration with the Fronius Symo range has been more thoroughly tested so that could be a better option if you want a more “out of the box” solution.
