Hello everyone!
An extensive search of the Victron community did not turn up any results. Now I hope this is the right place for my questions.
Fronius allows to connect multiple Fronius inverters by using their “Solar Net” (which seems to be RS485) like this:
In this example the first inverter would be a Fronius Symo M and the second one would be a Fronius Symo Light. Only the first inverter contains a Fronius DataManager with an ethernet interface.
If I connect this setup to a Cerbo GX will I be able to see the inverters as two separate devices in the menu of the Cerbo GX? Or do I need a Fronius DataManager inside every inverter to properly connect them to the Cerbo GX?
Does this setup affect the proper operation of ESS and zero feed-in?
Thank you!
Mario
