Hello.
I bought 3 victron balancers for my 48v system.
I looked at the manual and made a small drawing how I see the connections.
Will this work?
Greetings, niels.
Thx. I looked at this also in the manual that’s delivered in the box.
But my question is more on the midpoint. To the connections have to go from balancer to balancer and 1 line to the midpoint? That’s not clear for me on Victron’s drawing.
owenb79
(Owen)
26 April 2025 04:36
4
Should be something like this. The negative jumper cables must be full current rating and have a fuse.
Connect everything to the battery.
The diagram is just showing what is connected at a common point.
‘B1 0v’ is connected at the same point as ‘B2 Common’ and ‘B3 24v’
Thank you, so just like my first drawing I made?(first post)
owenb79
(Owen)
26 April 2025 08:41
8
No, your first drawing is wrong, your buss is on the opposite side to the Victron one, so you need to reverse everything like I have in my markup.
Thx!
They are working.
Indeed, I did not noticed that victron used the + on the other side than my system was.
No I understand why my drawing was not correct.
Now time for cleaning up the cables with cables ties.
Thx, niels.
