I connected the Victron GX to my B&G Zeus chartplotter via ethernet and as described in the Victron manual, an App appeared on the chartplotter that allows me to see and control the Victron devices that I have installed. Recently on the Cerbo I installed the Large version of Venus which also allows you to have Node Red and Signal K. From that moment on the chartplotter a new App appeared with the name SIGNAL K, I tried to open it but I see a white screen page. I would like to know what it is for and how to make it work. Thanks
Signal K isn’t a Victron app - you may have some luck with answers or suggestions how to use/integrate the app directly from Signal K: https://signalk.org/
I have the same problem
How it is possible run signal k admin from Navico chart plotter ?
