Victron App Ethernet requirement to Navico MFD
I’m testing my Cerbo GX Mk2 V3.54 at home with my B&G Zeus3 chartplotter. The Victron App is working perfectly with Ethernet cables through a Wifi router. When I try it through the Wifi connection between the Cerbo and the router, the MFD cannot see the Victron App.
I know the manual say it will not work with the MFD Wifi, but i see no reason it should not work when the Cerbo is Wifi to the router an MFD is cable to the router.
Can someone help, it will not be easy to wire Ethernet between the Cerbo and the router on my boat.
