Hi, new member. I have a 500A smart shunt installed DIY. My % leisure battery charge remaining number does not hold. Connecting with the App next day (for example) I find my 93% has returned to 100%. There has been no charging, don’t have solar, engine not started, starter battery relay open (so starter battery leakage is not charging the leisure battery). With all systems off, the smartshunt App shows 0.0A in either direction. Everything else is OK, could I just have a settings error? I cannot rely on accumulated %, it should be stored in the shunt. Thank You.
Related topics
| Topic | Replies | Views | Activity | |
| 5oo amp victron shunt stays on 100%charged | 1 | 72 | 14 April 2026 | |
| Smartshunt reset reset every time to to 100% soc | 2 | 197 | 30 November 2025 | |
| SmartShunt showing 100% SOC when battery is not at 100% | 8 | 570 | 27 October 2025 | |
| SmartShunt not showing correct values | 2 | 280 | 2 July 2025 | |
| Smart Shunt (500A) Has 10-15% SOC variance regardless of settings changed | 2 | 258 | 5 August 2025 |
