Victron 12/30 keeps getting interrupted
I have just bought the victron 12/30 charger to change my 280ah lifepo4 solar batteries off of a honda eu22i inverter generator. I haven’t used it much but last night I noticed the charge cycles keep getting interrupted. The first charge cycle it managed 40 minutes before being interrupted and then it was being interrupted every 2 minutes or so after
It’s not the generator cutting out as I have wired it in so everything runs directly from the generator when it’s in use on a 3 way rotary switch and my computer(desktop with no battery), monitor, lights etc weren’t cutting out at all and there were no overload warning lights on the generator
It’s also not the BMS cutting out as I have an app which tells me the status and if there are any faults which i checked at the time and nothing showed up.
Also, when it cut out the charger would display 0a 16v? Not sure if this is normal
Hope someone can help
Thanks
Did you ever find out the cause of this? Mine is doing the same thing. I have two 280ah in parallel, and it’s plugged into normal utility mains. It’s very frustrating because I can’t just leave it and expect it to complete and get to the storage phase. I am using 6awg cable from the IP22 to the battery bank.
