VenusOS 3.62 SignalK not working
I am running venusOS large on a raspberry.
Recently i upgraded from 3.55 to 3.60 and now to 3.62.
I also run GUI-Mods and Setup Helper.
SignalK did run fine under 3.55 but did not run with 3.60 and now with 3.62
Mario
I updated to 3.62 large on my cerbo mk II and am also having problems with my Signalk. I can’t load the page at 3000. It appears to be running (my db is getting updated occasionally) but sporatically, like it’s not getting any cpu. I am not running node red. Is anyone else seeing this?
Disable the mods, you will find it works. Gui mods and setup helper, along with others, are the main cause of upgrade issues.
Settings general modifications allows you to disable them. Then reload the firmware and reboot. All available in the modifications tab.
I restored back to 3.55 and everything works again.
It would. Those mods, or at least the versions you are using, are documented as incompatible.
I don’t use the gui mods.
That is just one example. There are numerous others.
If settings - general - modifications says you’re modified then something is configured.
If it’s clear then there is another issue.
Sure, but my settings are pretty simple. I only use a few plug-ins: AIS related, starlink and saillogger. All of those are compatible. It feels like something else is afoot.
You can disable all of them via that tab, push a refresh image and if it works on restart, then one has an issue.
You can enable them afterwards again.
When I upgraded to 3.62, The Signalk web ui was completely unresponsive. It appeared to be running very slowly because I would see periodic and partial updates to my database, maybe once every minute or two instead of once a second. There was no way that I could figure out how to get to the admin panel.
Hi, sorry to hear about your issues.
I recommend to go to the SignalK discord platform.
There are people over there that can help.
Alternatively, login to the GX over ssh (see google on how to do that) and check the signalk log files.
My signalk server runs without any issue under Venus OS v3.62..
Link to the Where to find support chapter:
It looks like there may still be a problem here. I have VenusOS 3.62 on a Cerber GX Mk 2, it runs well until I activate the signalk-starlink plugin then the signalk process starts to consume all the available cpu cycles. Within a few minutes the signalk service restarts and contiues to cycle until I disable the starlink plugin. I have an Starlink mini and the web interface is on port 80 vs 9200 so I wonder if the plugin just isn’t compatible with the mini.
