I notice that after installing the beta7, over beta6 the energy flows on the display (over view page) connected to the serbo doesn’t flow anymore after some small time.
In the beta6 it function normal. When I look in the VRM its good, and when I open remote console its also ok.
Glad its working, so I have to look somewhere on my side, but not shore where to start. Memory issue maybe ,because its working for a schort time, than it stops.
Short time is less than a minute. Strange thing is that it in vrm, and remote console normal works.
Most likely, this happens because the CPU load is too high. Unfortunately, the UI currently does not indicate that it has disabled animations, we are working on adding an indicator for this. I can reproduce myself by running a CPU benchmark.
To confirm, you can try to disable some optional services like Node-Red to save some resources, the animations should start working again whenever there is sufficient headroom.
And the animations are only stopped on the local display because VRM and the remote console render the animations themselves and do not use CPU resources of the Cerbo.
Tanks for confirmation. I did boot yesterday de beta7 again, en in the beginning it was working, than it stops for I think 5 til 10 minutes. so I look to cpu use and ssh into the serbo to check with top command. Seems normal for me, but I’m not an expert. After 5 til 10 minutes its start working again, and still works. in the meantime it reboots one time, I think because of the watchdog.
my cpu usage is between 55 and 65%. And the top command shows mostly the gui-v2. To disable nodered is not an option for now. Only think what is not original is the open dtu integration.
But I’m happy that it is noted., and for now working again.
Have the same but as far as I remember not only since 3.80 but also 3.7x
My Setup is Cerbo with HDMI - monitor (NO Victron Touch) + USB Mouse
My animation stops exactly after “no menue action” within the programmed “display off time” , display stays on, most values are updated correct.
When pressing a mouse button it starts again.
when setting the “Display Off Time” to “never” it runs for ever
