Venus OS Update V3.42 -> V3.62 and NodeRed
I’d like to update Venus OS on my cerbo-gx device. Any ideas or tips to do this without running into some traps or problems. How’s about updating Node-Red? Do I have to do it manually? Cheers M
Hi, and welcome!
Just read the docs and follow the instructions. Everything you need to know is already in a manual, changelog or posted here somewhere.
Okay thanks!
Tip: make sure that you have a backup of your flows.
It’s a process done many times but the guidance stands, don’t update for update sake. If you need functionality or fixes then update.
If you have modded your system, be careful, as the main issue is always incompatible customisations and mods which break the system after an update.
Made it
