How do I update node red and package node-red-contrib-Victron?
I’m running VenusOs 3.54 large on my raspberry pi 3B+. First update that I’m using large, so clean and fresh (coming from normal 3.31, to normal 3.54 and after that large 3.54, so that I could save SDimages of all stages).
Node red is version 3.1.10
Node-red-contrib-Victron is 1.5.23 (which is having relay control issues)
Victron-VRM-api is 0.2.10
It’s not giving me the ‘update’ option like I get when I install new packages.
What I tried for the package:
Uninstall the package through command line → no success
Removing all files manually. Install latest version with succes, but after a restart the package is gone. It seems that is was only in the .node-red folder (data/home/nodered/node-modules) and not in the usr folder (urs/lib/node-modules).
Tried updating npm, node and node-red using the way it was described for Linux based systems.
A lot of errors, of versions being to old to be updated!
Current versions:
npm v10.7.0
node.js v18.20.3
Node-red v3.1.10
Then I found another solution voor node red:
Go back to older normal venusOS, remove .node-red folder in data/home/nodered. Then update to latest large version. Result: still old node red.
Is this a specific Raspbery pi issue with venusOS or also on a cerbo?
Hoping someone has a solution, because I’ve spend hours and hours on www.
