Venus OS (Raspberry Pi) claiming Multiplus is off
I have Multiplus II connected to Raspberry Pi with USB MK3. It worked for few weeks but now every time I check the status in the morning Venus OS says Multiplus is off. After reconnecting MK3 it shows correctly “inverting”. Raspberry pi is not connected to internet at nights but it should not matter. What could be the issue here?
Is the Multi a separate unit for charging only? I could be wrong but I always assumed that the MK3 is meant for configuration, not permanent connection. Unless it’s for a separate unit to charge only.
Mk3 is required by a Pi for VEBUS access.
Ok
