as of yesterday i was testing new virtual -Switches to configure modes or scenes , im using qty 4 IO extender modules , which are working well, however this morning beta version 3.63-2 upgraded automatically and i have lost virtual switch options Node RED.
I got a failed firmware install message. It tried to install 3.63 too. I’m still on the 3.70 beta that has the virtual switches.
Disable automatic updates when you are on beta, especially if you are building features based on beta developments. If the testing shows problems, the feature can be removed. Virtual switches got removed from the 3.60 beta part way through. And keep an eye on the sticky thread in the Benus OS beta section and check the changelog before updating. All info is supplied to avoid suprises.
