Hello. I was using Virtual device with my installation and after last update (20250124162752) Node is writing not found. My flow stopped because of unknown node. Is this a known bug ?
Are you on a beta, if so, this really needs to be stated when opening a topic ? Do you auto update? In which case your system downgraded to the V3.5x release stream, as announced on the topics for beta, so issues will happen for code based on a later release.
Yes i am in Beta. And yes i have Auto update turned on. Currently it is showing verion 3.54~1.
So as explained, your system rolled back to older code, so it will break. Revert to the backup copy of 3.60 and it will work again. Auto updates aren’t wise when the beta program often hops backwards to back-port some changes.
If you want to take part in betas, it is important to stay up to date on release information and known changes, bug reports etc.
This helps avoids issues and duplicate topics.
At least yours is an easy fix.
Okay thank you a lot for info ! Have a great day ![]()
