Hi Dean. The Fronius is on the grid side of the Multiplus II i.e. AC IN. I found a separate thread on this same issue from May and it suggested changing the location of PV to AC OUT - which I tried but this then added the PV power to the loads (which is also wrong).SOLVED - VRM Grid Power Incorrect - #4 by Chris78 I think it’s a firmware bug in the Venus display (since VRM is showing it correctly).
ertcom
(David)
5
Related topics
| Topic | Replies | Views | Activity | |
| Strange Wattage view on VRM on EES system | 4 | 423 | 27 August 2025 | |
| AC Loads with AC connected solar | 20 | 788 | 25 July 2025 | |
| VRM and Venus GUI show different grid/AC Inverter flows | 0 | 111 | 27 August 2025 | |
| Data Error: PV Inverter on AC-Out of MultiPlus II 48/5000 Generation showing as Consumption | 1 | 66 | 29 May 2026 | |
| SOLVED - VRM Grid Power Incorrect | 3 | 258 | 24 July 2025 |
