Starting to use Carlo Gavazzienergy meter in my house (as study first) I’ve attached a Venus GX device with 3.52~4 Beta normal version.
I’ve connected the two EM111 to it using a RS422 to USB converter ( already tested and is use on an other installation) The EM111 have been set up with address 1 and 2, speed 9600.
1 - One is conneted to lights house circuit and the other on Power plugs… So typicaly they are AC load only. Using as AC LOAD, nothing appear on the Gui Screen, only when going into device list we can see the power. I there a way to see the total with the Gui or in the VRM ?
2 - So just to understand and testing, I setup the energy meters in this way :
- 1 energy meter as Grid (Lights) and the other one as Generator (Power plugs)
Started up the Genset manually and setup the AC input accordingly.
So here the view in the VRM : (all seems to be OK)
With the overview view in the Gui : (bullets are missing and no more the Genset Status)
And Brief view only Grid input is appearing …
Something to correct with the Firmware ? or setup problem ?
Xavier.
