Using VE Flash, I want to update my 2014 Multiplus Compact 24/1600-40 with the new processor 2616154 and new firmware, to give solar priority.
That could be file 2616209.vff. The VE Flash programme gets stuck on the “Prepare your system” screen. So the screen where I can select the COM port does not appear. When I load VE Configure, the Multiplus is detected. (MK3 cable to USB).
I am using a Windows 10 laptop with all updates installed. Should I try another laptop running Windows 11? Or could there be another cause? No other Victron products are connected via the VE bus.
