Ve direct cable female coupler/panel mount
Looking for a panel mount or coupler for the VE direct cables. Does anyone know of such thing? Or parts to possibly make my own.
I’m making a frame for components and I want to be able to plug in a VE Direct to the Frame, instead of running a wire in and out of the frame. Its the only wire I don’t have a panel mount solution for.
As far as I know the Ve Direct connector is a JST PH 4 pin connector with 2.00mm pitch.
I’m not sure if there are any panel mount versions for this connector…
Maybe you can solder one on a small pcb, and mount this board behind you own panel.
