Charging port
Hi there !
I wonder if there are any charging ports available from Victron? I have a simple setup with a MPPT Charge controller and 2 Victron batteries 12V 22Ah connected in series. The Victron charger comes with clamps or bolt attachments. I need to install a charging port in my structure which has a nice design like a XLR, Jack or Magnetic, etc. (battery are enclosed and I don’t wanna open the box to access them every time I need to charge them because in some cases my setup will be charger by a person who has no idea about connections etc.)
What solution would you recommend? What type of charging port? Can I cut the Victron charging leads and connect an XLR connector? or it would affect a functionality of Victron in any way?
How do I connect 24V 20W solar panels from Victron? Do I solder wires or use a terminals for a M3 bolt?
Let me know guys please !
