What and when are the requirements of the VE CAN network to be powered?
For instance, if building a traditional NMEA backbone, with terminators at each end, 2 x NMEA devices (that do not require power on the network, and only have CAN low and high cores connected internally) on drop cables, 2 x Victron MPPTs connected to the NMEA backbone each via VE CAN to NMEA cables, a Cerbo, and a Lynx BMS, again each connected to the backbone via VE CAN to NMEA cable. Do the VE CAN devices of the Lynx and MPPTs require the network to be powered? Assume if they do, then 24v is ok for the network power? Cerbo obviously does not require power, but can power the network if required.
