I am installing an Integrel Generator on my boat and it needs a connection to the BMS/Ekrano GX using DVCC. The two options are NMEA2000 (With the VE-Can to NMEA cables) or VE-Can with a standard VE-Can cable. Is DVCC broadcast regardless of VE-Can or NMEA or does it only work over a native VE-Can connection? I’d prefer to use NMEA because all the Victron and Integrel data needs to be on NMEA anyway for my chart plotters. My current wiring diagram looks like this … the first one shows the Integrel Generator and associated components, the second the rest of the charging sources and loads - merging the two gives the entire system.
Related topics
| Topic | Replies | Views | Activity | |
| Using cerbo gx with Xantrex inverter via nema2000 | 2 | 353 | 2 April 2025 | |
| Cerbo GX 2 intergation with Raymarine Axiom vis NMEA2000 | 3 | 332 | 19 March 2025 | |
| Need cable network selection help CCGX, Multiplus II, eg4 ll 24v | 12 | 222 | 27 March 2026 | |
| Connecting Balmar Alternator/Regulator to Cerbo-S GX via VE.can/NMEA2000 | 0 | 284 | 28 July 2025 | |
| Integrate Orion TR-smart, Orion XS and MPPT Solar controller into Garmin Chartplotter via CerboGX? | 3 | 128 | 14 August 2025 |
