VE.Bus System - Multiplus-II - Generator [288] - BMS lost: Alarm
Hello All
I have 3 Multiplus 48/5000 in 3 phase setup (GRID). And in addition a single Multiplus 48/5000 connected to a generator. This multiplus is used in charger only mode, and connected via a MK3 USB cable to the Cerbo GX. This so that it can be controlled using node-red.
I don’t remember which ~build but since the new beta 3.60 versions I now get the message “VE.Bus System - Multiplus-II - Generator [288] - BMS lost: Alarm”.
Toggling the option “Managed battery controls all Multis and Quatros” don’t seem to make a difference. Clearing the alert works only temporary.
Any ideas how I can get this issue resolved?
Is there nobody with a similar setup having this issue?
thanks @bwbboot for the report, not sure but we’ll look into it.
