Dear All,
First I would like to thank everyone that contributed to this question in advance. Please bare with me.
I would like to know if there are any USB to VE CAN computable and affordable converters.
Also I would like someone to clear up the difference between ve. Can and RS485
My baterry supplies both CAN H/L and RS485A+/B-
What I am actually connecting where?
Thank you in advance
Dear All ,
I checked online and I found this.
So my battery should use CAN bus ( L and H ) so I should find an adapter that is a USB to CAN bus that is compatible with the RPI image.
I found this from the old forum
And a homemade terminator with a 120ohms resistor on an RJ45 connector to terminate the open end of the battery for said CAN Bus
So I think I will be able to make the device work as expected I suppose
Thank you for your help
Okay, so after the CAN bus to USB arrived, I’ve tested it with a lithium battery and we got coms.
So all works good at least with this battery I tested.
–Further update –
Voltogo batteries arrived and everything worked as expected ! Thank you
